10-31-2013 05:53 AM - edited 03-19-2019 07:28 AM
I am trying to export message from Unity Conn 8.6 to a local disk but everytime I get the following errors. It happens only when I select the option to export the messages. I can export all other things such as subscribers, call handlers etc. I am using administrator account (no voicmail box). Does anybody has solution to this problem?
[Thread 001], [13/10/31 08:43:29], Checking to see if WAV file download functionality works, this may take a moment...
[Thread 001], [13/10/31 08:43:29], Checking IMAP connectivity capability before starting export.
[Thread 001], [13/10/31 08:44:29], (error) Failed establishing IMAP connection for message backup. Client error=Failed to attach to Connection server on port 7993 for IMAP login in AttachViaImap. Client error=ChilkatLog:
Connect_Imap:
DllDate: Aug 5 2012
UnlockPrefix: LNDBRGIMAPMAILQ
Username: DCA033501:xxxxxxx
Architecture: Little Endian; 32-bit
Language: .NET 4.0
VerboseLogging: 0
hostname: 10.x.x.x
port: 7993
ConnectTimeoutMs_1: 60000
calling ConnectSocket2
IPV6 enabled connect with NO heartbeat.
This is an IPV4 numeric address...
AddrInfoList:
AddrInfo:
ai_flags: 4
ai_family: 2
ai_socktype: 1
ai_protocol: 0
ai_addrlen: 16
ai_canonname: (NULL)
--AddrInfo
--AddrInfoList
Connect using IPV4.
ipAddress1: 10.x.x.x
timeout waiting for connect to complete
numSec: 0
numMicroSec: 766000
HostOrIpAddress: 10.x.x.x
SocketHandle: 0xa7c
sockError: 10022
Connect function failed..
SocketError: WSAEINVAL An invalid argument was supplied.
failReason: 7
connect failed.
--Connect_Imap
--ChilkatLog
Solved! Go to Solution.
04-17-2014 05:59 AM
Can I use COBRAS to move everything except voice messages between Unrestricted and Restricted versions?
04-17-2014 06:30 AM
yes, all other data comes in via ODBC or via HTTP (greetings/voice names and such come via HTTP downloads) which are not locked down on the unrestricted version.
be sure to use the updated builds of COBRAS I mentioned above that are currently on the temporary download page (we'll be moving them to the main page this weekend):
http://www.ciscounitytools.com/Temp/
11-20-2016 08:41 AM
Hi Lindborg,
Now I am on this situation,
I have Unity 8.6 unrestricted Version. After reading this thread, I use /UseCUMI to run COBRAS and got following error, if I don't select "Include Voice Messages" then works fine every time. Please help me I need to Backup voice messages as well..
Thanks!!!!
[Thread 001], [16/11/20 11:21:40], Checking to see if WAV file download functionality works, this may take a moment...
[Thread 001], [16/11/20 11:22:14], Checking CUMI connectivity capability before starting export.
[Thread 001], [16/11/20 11:22:27], Connected to server for CUPI functionality using SSL3
[Thread 001], [16/11/20 11:22:27], (error) failed to log into Connection server via CUMI using the login credentials provided:Login failed to Connection server:10.20.2.7. Details= WebCallResults contents:
URL Sent: https://10.20.2.7:8443/vmrest/version
Method Sent: GET
Body Sent:
Success returned: False
Status returned -1:-1
Error Text: Could not create SSL/TLS secure channel
Raw Response Text: Could not create SSL/TLS secure channel
Total object count: 0
Status description: Could not create SSL/TLS secure channel
[Thread 001], [16/11/20 11:22:43], Unable to log into Connection to extract messages. Review the output below and the help file for details and troubleshooting steps.
11-20-2016 09:05 AM
as a side note, tossing a question into the middle of a long thread like this is a good way to have it be missed...
This is not actually related to that command line but some security updates Microsoft has recently started rolling out on Windows that restricts older SSL3 HTTPS connections (used by CUMI for versions of Connection older than 10) - I have a patched version of COBRAS export I just posted - 8.0.75 - which you can download off my temp page here: http://www.ciscounitytools.com/Temp/
it should force the SSL3 attachment to go through when attaching to Connection versions older than 10.0 which use TLS.
11-20-2016 11:52 AM
Great, Looks it is working now. Thanks Lindborg!!!
03-06-2018 09:34 PM
Hi Mate,
Could I have this same Unrestricted 8.6 export unrestricted COBRAS available again?
THanks,
yav
12-03-2023 01:36 AM
I know this is a very old and marked as solved post, but thought it would be good to add what is needed for this to work in CUC 12 and later. For that the CUC needs to be set to use encryption from the CLI, by default this is disabled.
To turn it on make sure that Export Control is allowed in the license manager and that encryption is turned on from CLI with the command "utils cuc encryption enable".
For more details on this please see this post. Unity Connection 12 secure IMAP (port 7993) not working
