Configuration problem w/ incoming call
Hello there, just new here and w/ cisco CCME version 4.0
My scenario is, we have a C3845 named PBX01 w/ CCME v 4.0 connected to PSTN and C3845 named PBX02 w/ 7911G ip phones connected (local numbers are 1...) to it.
I want to configure local number 1038 to receive an incoming call from PSTN 701102001. the IP phone local 1038 is connected to PBX02. What i did is configured the translation-rule from PBX01 to translate incoming 701102001 to 1038 and point it to PBX02. when i test it by calling from outside, the local 1038 is ringing but i can't hear a dtmf tone and when the phone is pick up the connection is cut or we can't hear each other. I already included a voice class codec configuration on my dial peers but it is still not working. Pls check my attached file w/ includes some of my config in PBX01 and PBX02.
Pls assist me if my configuration in Translation-rule, in voice class codec and dial peers are correct.
thanks
1 REPLY
Re: Configuration problem w/ incoming call
For PBX01:
translation-rule 1
Rule 1 ^701102001 1038
voice-port 1/0/0:15
translate called 1
dial-peer voice 1038 voip
destination-pattern 1038
session target ipv4:10.10.254.1
dtmf-relay h245-signal h245-alphanumeric rtp-nte cisco-rtp
dial-peer voice 701102001 pots
destination-pattern 701102001
translate-outgoing called 1
incoming called-number 701102001
direct-inward-dial
port 1/0/0:15
dial-peer voice 10 voip
destination-pattern 1...
dtmf-relay h245-signal h245-alphanumeric cisco-rtp
call-manager-fallback
max-conferences 12 gain -6
transfer-system full-consult
For PBX02:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
dial-peer cor custom
name 9T
name 1...
dial-peer cor list moi-VIP
member 9T
dial-peer cor list moi-Local
member 1...
voice-class codec 1
corlist incoming moi-VIP
corlist outgoing moi-Local
voice-class codec 1
dtmf-relay cisco-rtp h245-alphanumeric h245-signal rtp-nte
ephone-dn 38
number 1038
caller-id block
corlist outgoing moi-VIP
228
