connection plar problem with cue and srst
i don't know, but it seems i made a stupid mistake somewhere in my config.
i have this router that works fine when it's connected to my callmanager
and when i disconnect network for srst test , it goes to fallback and everything works fine but if i call the fxo port it will not transfer to my AA in my CUE
i tried with connection plar opx and AA didn't pickup the line and when i tried with connection plar i heard busy signal.
i attached config file
any help would be appreciated
1 ACCEPTED SOLUTION
Green
Re: connection plar problem with cue and srst
You could try these additional lines depending on your IOS level.
For IOS 12.3(13)T or earlier
use
config#call application alternate default
For IOS 12.3(14)T or later
use
config#application
(config-app)#global
(config-app-global)#service alternate Default
These commands hand the service to DEFAULT when MGCP is not available.
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080144630.shtml
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
Green
use
use
config#application
(config-app)#global
Hope this helps
Alex
Thanks for help
worked!!!
appreiated
216
