Control analog phones CSS
Dears,
Today i am asking for help with my voice network, i have analog phones connected to PBX with no PRI connected directly to PBX instead the PRI line is directly connected to voice gateway, this voice gateway connected to both VOIP network (CUCM, IP Phones) with E1 port and connected also to traditional network (PBX, analog Phones), BTW the voice gateway protocol is H323.
i am able to control IP Phones calling privilage with the help of CUCM calling search space, while i am not able to control analog phones calling privilage except from PBX side which require me always to get PBX men in any change for calling privilage changes,
i need to remove all restriction from PBX and only asks PBX men to route all calls to my voice gateway, which will control this calling privilages, i know that there is a feature called COR "Class Of Restriction" but i don`t know if it suit in my case and how can i use it.
Please Help
  • Unified Communications Applications
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Control analog phones CSS
Give this a try. It may not be exact but should get you close. You can use the 'show call active voice brief' command to verify calls are hitting the correct PID (i.e. dial-peer) on inbound/outbound legs.
dial-peer cor custom
name pbx
name pstn-local
name pstn-toll
name pstn-international
name cucm
dial-peer cor list INCOMING-PBX-ALLOW-LOCAL
member pstn-local
member cucm
dial-peer cor list INCOMING-PBX-ALLOW-TOLL
member pstn-local
member pstn-toll
member cucm
dial=peer cor list INCOMING-PBX-ALLOW-INTERNATIONAL
member pstn-local
member pstn-toll
member pstn-international
member cucm
dial-peer cor list OUTGOING-PSTN-LOCAL
member pstn-local
dial-peer cor list OUTGOING-PSTN-TOLL
member pstn-toll
dial-peer cor list OUTGOING-PSTN-INTERNATIONAL
dial-peer voice 1 pots
description Inbound PSTN
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
direct-inward-dial
port 0/0/1:15
dial-peer voice 10 voip
description CUCM Publisher
destination-pattern ....
session target ipv4:192.168.2.100
voice-class codec 1
voice-class h323 1
dtmf-relay rtp-nte h245-alphanumeric
no vad
dial-peer voice 11 voip
description CUCM Subscriber
preference 1
session target ipv4:192.168.3.100
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 20 pots
corlist outgoing OUTGOING-PSTN-???
destination-pattern 8........
port 0/0/0:15
dial-peer voice 21 pots
preference 1
port 0/0/1:15
dial-peer voice 22 pots
destination-pattern 80T
port 0/0/0:15
prefix 0
dial-peer voice 23 pots
preference 1
port 0/0/1:15
prefix 0
dial-peer voice 24 pots
destination-pattern [89]01[012]........
port 0/0/0:15
forward-digits 11
dial-peer voice 25 pots
preference 1
port 0/0/1:15
forward-digits all
dial-peer voice 26 pots
translation-profile outgoing Analog_Phone_Out
destination-pattern 9[234].......
port 0/0/0:15
forward-digits 8
dial-peer voice 27 pots
preference 1
port 0/0/1:15
forward-digits 8
dial-peer voice 28 pots
description PSTN Services
destination-pattern 91...?
port 0/0/0:15
prefix 1
dial-peer voice 29 pots
preference 1
port 0/0/0:15
prefix 1
dial-peer voice 31 pots
translation-profile outgoing Analog_Phone_In
destination-pattern 636[^0]
port 0/1/0:15
forward-digits all
dial-peer voice 30 pots
description Legacy PBX faxes
destination-pattern 63[7-9].
port 0/1/0:15
forward-digits all
dial-peer voice 32 pots
destination-pattern 65[0-5].
port 0/1/0:15
forward-digits all
! PBX Incoming Dial-Peers Per Extension
corlist incoming INCOMING-PBX-ALLOW-???
answer-address 6301
dial-peer voice 33 pots
answer-address 6302
! Continue as-needed...
Please remember to rate helpful responses and identify helpful or correct answers.
VIP Super Bronze
What type of interface is the gateway connected to the PBX with?
CoR is correct but it depends on calling<->called destination pairs to impose a restriction. Example: ANI 1234  calls DNIS 9011T. To use it we either need an interface that provides ANI (e.g. ISDN) or a unique physical interface for each endpoint so we can subsititue the interface for the ANI.
If the interface provides ANI you would need to construct your incoming POTS dial-peers to use answer-address instead of incoming called-number. This way you can create a unique dial-peer per PBX extension and apply an incoming CoR to it.
Dear Jonathan,
Voice gateway connected to PBX through E1 interface.
Which way is better and please give me an example helps me to know how to control analog phone calling privilege without affecting IP Phone calling privilege which controlled by CUCM
VIP Super Bronze
Post your existing dial-peers and I'll suggest what to add. Ensure that you specify what voice-port the PBX is vs. the PSTN.
Dear Jonathan,
Thanks for your help, i really appreciate that, please find attached are copy of my voice gateway configuration
VIP Super Bronze
name pbx
name pstn-local
name pstn-toll
name cucm
member pstn-local
member cucm
member pstn-local
member pstn-toll
member cucm
member pstn-local
member pstn-toll
member cucm
member pstn-local
member pstn-toll
direct-inward-dial
port 0/0/0:15
direct-inward-dial
port 0/0/1:15
voice-class codec 1
voice-class h323 1
no vad
preference 1
voice-class codec 1
voice-class h323 1
no vad
port 0/0/0:15
preference 1
port 0/0/1:15
port 0/0/0:15
prefix 0
preference 1
port 0/0/1:15
prefix 0
port 0/0/0:15
forward-digits 11
preference 1
port 0/0/1:15
forward-digits all
port 0/0/0:15
forward-digits 8
preference 1
port 0/0/1:15
forward-digits 8
port 0/0/0:15
prefix 1
preference 1
port 0/0/0:15
prefix 1
port 0/1/0:15
forward-digits all
port 0/1/0:15
forward-digits all
port 0/1/0:15
forward-digits all
answer-address 6301
answer-address 6302
Dear Jonathan,
i will give it a try and thanks very much for your help.
179
