CUCM 7.1.3 Not booting-CUCM 7.1.3 Not booting-Kernel Panic - not syncing: Attempt to kill init!
Sunish Nair
Server is not booting and getting following error "Not booting-Kernel Panic - not syncing: Attempt to kill init!"
For troubleshooting the particular issue i have done following things;
1. Rebooted the Server 1 or 2 times, still no luck.
2. used the Recovery CD for rectifying the issue and tried all the option which is available in the Recovery disk, unfortunately no luck (:
Kindly suggest me if any faced this issue and found any resolution for the same. Here i am attaching the snap shot of the error for your reference.
Thanks in Advance.
Manish Gogna
Hi Sunish,
What are the hardware specs. Is it an MCS server or is it a virtualized lab enviroment? If it is a lab system, make sure the esxi version is at least 4.x.
Manish
