CUE AA script not allowing input
CUE version is 2.3(4). Using an auto attendant script that allows user input during the greeting. This works fine the first time through. If I enter an invalid extension, I get the message "You have entered an invalid extension. . ." The script then loops back to the main menu. When this happens, I can no longer enter an extension or other menu options. It seems that the prompt is set to not allow interruptions. However, it's setup correctly as it works the first time through. Script is attached. Any thoughts?
Brandon
Everyone's tags (1)
267
