CUE AutoAttendant After Hours (S3) & Business Hours (S2) Problem
I have attempted to combine the sample autoattendant scripts in order to provide after hours support in a CUE script. When the script is uploaded & run however, it rings three times and then plays the system error message. Has anyone had any success in adding busines hours support to S2 sample script?
Re: CUE AutoAttendant After Hours (S3) & Business Hours (S2) Pro
The script itself looks OK. There's probably some other run-time parameter missing/misconfigured, such as a trigger or the app in the config.
Do you have a 'sh ccn trigger' and 'sh ccn app"?
The trigger must have the number that is presented to CUE when dialing in; it must be enabled and be the correct type (jtapi or sip), and have max sessions >=1. It also needs to be pointing to the correct application.
The application then needs to be enabled, must point to the right script (PCH.aef), have max sessions >=1.
If those all check out, then do a 'clear trace', make a test call that generates the error, and do a 'sho trace buff long'. It'll generate quite a bit of information, but will eventually stop scrolling. Look for the first EXCEPTION message; usually that message and sometimes the messages right before that indicate what it doesn't like.
Thanks so much for the reply. I still can't see whats wrong? I have included the show statements for your reference. Any help is greatly appreciated!
sh ccn app
Description: pch
Script: pch.aef
ID number: 5
Enabled: yes
Maximum number of sessions: 6
Janice: 203
Mary: 202
Bruce: 204
Mike: 202
Candice: 201
S2_OfficeDir: S2_OfficeDir.wav
S2_FaxInfo: S2_FaxInfo.wav
EmergencyNumber: 98056965029
S3_AfterHours: S3_AfterHours.wav
S3_MainMenu: S3_MainMenu.wav
S3_SystemProblems: S3_SystemProblems.wav
John: 201
S2_LocationInfo: S2_LocationInfo.wav
OfficeGDM: 600
S2_SystemProblems: S2_SystemProblems.wav
Janet: 203
S2_MainMenu: S2_MainMenu.wav
sh ccn trigger
Type: SIP
Application: voicemail
Locale: systemDefault
Idle Timeout: 10000
Enabled: yes
Type: SIP
Application: autoattendant
Idle Timeout: 10000
Enabled: yes
Type: SIP
Application: promptmgmt
Idle Timeout: 10000
Enabled: yes
Maximum number of sessions: 1
Type: SIP
Application: businesshours
Idle Timeout: 10000
Enabled: yes
Type: SIP
Application: pch
Idle Timeout: 10000
Enabled: yes
sh br b t
UC500-CUE# sh trace buffer tail
Press to exit...
5231 08/22 17:04:39.866 ACCN SIPS 0 OutLineListener:---------------- LocalLine-612 notified about an InboundCall GCID=46F37F1C-504311DC-80BDCB5C-A36A88B0@10.1.10.2 from=203 to=612
2965 08/22 17:04:49.807 ACCN APMG 0 UNABLE_INVOKE_APP:Unable to invoke application: Application=App[name=pch,type=Cisco Script Application,id=5,desc=pch,enabled=true,max=6,valid=false,optional=[cfgVars.java:199)
Isn't the script name in all caps? That stuff is case sensitive, I believe. Make sure it matches the case under the ccn app pch.
I changed the script name all lowercase & verified that all of the appropriate files have been loaded. It still gives me the system error message. This is driving me nuts. Any other ideas? Your help is greatly appreciated.
You are integrated with CME, right? If so, could you just grab a 'show run', 'show software ver' and the 'show trace buff long' from the system (please do a 'clear trace' prior to doing this) after making a call and either attach it here or send it to ask-cue-editor@external.cisco.com
Here are the show commands attached in a log file as per your request. Thanks! Please note this is a UC520.
What CUE version (show software version) is this? What version of the CUE editor did you use? Also, this mentions s2_main-office-dir.aef. Is that a different script than what you posted?
The version of CUE editor is 3.0(1) and the software of the CUE module is:
UC500-CUE# sh software ver
Software Version 2.3.4
Build Number 1
Installed Packages:
- Installer 2.3.4.1
- Thirdparty 2.3.1.0
- Bootloader (Primary) 2.1.14
- Infrastructure 2.3.2.0
- Global 2.3.4.1
- GPL Infrastructure 2.2.1.0
- Voice Mail 2.3.1.0
- Bootloader (Secondary) 2.1.14
- Core 2.3.0.2
- Auto Attendant 2.2.1.0
Installed Languages:
- US English 2.3.0.0
Ah, that's not good... You need to use the CUE 2.3 editor. You can use an older editor to load a script to a newer version CUE, but not the other way around. I'm not sure why it's even allowing you to do that. It shouldn't. Unfortunately, the problem with that is that it would be considered a defect in the 2.3 CUE software, which, by definition, wouldn't be fixed until a later software; so there's nothing that could be done in that software version itself. I'll have to take a look at that.
In any case, go ahead and get the 2.3 CUE editor. You will probably have to recreate the script. In most instances it won't let you open a script from a newer CUE script editor. Once the file has been saved with 2.3 editor, upload it and you should be further along.
159
