CUE problem
      I am trying to install CUE on AIM cisco 3825. I did the initial configuration and when the device is reloading its stuck .. may its trying to reach my DNS server as I have given my dns details in initial setup. Please let me know how can i remove all the configurations and start it from the begining.
Retrying install. LDAP objectClass.bdb is missing, system otherwise OK
Serial Number: FOC13503EUB
read workflow properties
finish setting sysdb callagent
INIT: Entering runlevel: 2
********** rc.post_install ****************
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
==> Starting CDP
STARTED: ntp_startup.sh
STARTED: LDAP_startup.sh
STARTED: SQL_startup.sh
STARTED: dwnldr_startup.sh
STARTED: HTTP_startup.sh
STARTED: probe
STARTED: fndn_udins_wrapper
STARTED: superthread_startup.sh
STARTED: ${ROOT}/usr/wfavvid/run
Waiting 282 ...
CUE problem
I am still waiting for some one to reply and just give me an idea ???
CUE problem
Does the CUE boot up properly?
Please rate replies and mark question as "answered" if applicable.
CUE problem
here it what happens ...
Initializing memory.  Please wait. ... 256 MB SDRAM detected
BIOS Version: Cisco SE-AIM 01.02
BIOS Build date: 08/14/03
System Now Booting ...[BOOT-ASM]
Please enter '***' to change boot configuration:
Loading disk:/bzImage ... done.
Verifying ... done.
Starting Kernel.
Platform: aim
Using existing trace log
Cisco init
INIT: version 2.86 booting
mounting proc fs ...
mounting sys fs ...
mounting /dev/shm tmpfs ...
reiser root fs ...
Reiserfs super block in block 16 on 0x801 of format 3.6 with standard journal
Blocks (total/free): 248976/170123 by 4096 bytes
Filesystem is clean
Filesystem seems mounted read-only. Skipping journal replay.
Checking internal tree..finished
FILESYSTEM CLEAN
Remounting the root filesystem read-write...
kernel.sem = 1900 4000 32 100
vm.overcommit_memory = 1
                Welcome to Cisco Service Engine
Setting the system time from hardware clock
********** rc.aesop ****************
Populating resource values from /etc/aim_rsrc_file
Populating resource values from /etc/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/aim_rsrc_file
Processing manifests . . . . . . . . . . . . complete
==> Management interface is eth0
==> Starting CDP
STARTED: probe
Waiting...1
Doesnt comes to the prompt
CUE problem
It seems that the OS is corrupted. I'd suggest you perform a restore.
Refer to this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_0/installation/guide/upg3boot.pdf
CUE problem
Thanks for the support. I will keep the thread opened and see if some one else can keep more input on the issue.
287
