CUE system prompt
Does someone know if it is possible to edit/change the default prompt of CUE 3.2 ?
For instance, change the "please record after the tone".
Thx
Fabian
1 ACCEPTED SOLUTION
Re: CUE system prompt
You can only enable or disable the playing of that prompt via the command:
voicemail conversation caller recording-prompt
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/administrator/voicemail/3VMpara.html#wpmkr1012072
Ok, Nice.
Thx
Fabian
250
