Silver
CUOM & Unity 4.2(1) monitoring issue
Hi Guys,
Any tricks to getting CUOM to see Unity properly?
Basically I have CUOM 2.0.1 and the Unity servers show as "Monitored" but CUOM does not actually group them as Unity servers therefore it doesnt let me do MWI synthetic tests on them.
However in the Service Level view, they look like unity servers! :)
I believe our windows management acct and SNMP is ok.. as the server shows monitored and no alarms. It also occasionally detects service down or failover / restart events.. so it looks like it can see WMI.
Cheers,
Tim
Re: CUOM & Unity 4.2(1) monitoring issue
Do you have the Unity RSK installed?
Silver
Ah.. that is a good question.. i didnt realise it was a requirement for CUOM.. i will test it out and let you know!
Cheers,
Tim
Silver
Another quick question.. RSK install says EMS is required to get the most benefit..
If we are using CUOM, do we need to install EMS as well?
Cheers,
Tim
Tim,
Yes install/configure SNMP,EMS and RSK (for the CDP mib to be enabled). Rediscover the Unity server in CUOM 2.0.1 and it should go to fully monitored.
scott
123
