Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CUPC not able to make call in softphone mode
I am using the following:
1. CUCM 7.x
2.Presence 7.x
3. CUPC 7.x
I am facing a problem as follows:
1. In softphone mode i am not able to dial any other phone from CUPC i am getting a error message in CUPC that " out of service "
2. In dekphone phone the call is landing and i can recieve the phone call but i am not able to hear anything from CUPC throug a attached headphone in my Laptop where cupc is installed.
The CUPC softphone is getting registered in CUCM as a SIP phone.
Any help in resolving the issue will be apreceiated.
Red
Re: CUPC not able to make call in softphone mode
In deskphone mode, the audio goes to your deskphone. that's why you couldn't hear anything on computer.
Please let me know:
1) What's the detailed version of CUCM
2) What's the detailed version of CUPC (client)
3) What's the dialed string (including any non-numeric characters)
4) Have you configured CSS (Calling Search Space) for CUPC?
Thanks!
Michael
http://htluo.blogspot.com
Hi htluo
1. The CUCM version is 7.0(1)
2. CUPC version is 7.0(2)
3. DIALING STRING IS 4xxx
4. Yes CSS has been configured for CUPC line
Red
Is there a comma in the display name, e.g. "Smith, John"? CUCM 7.0(1) cannot handle the comma. You either remove the comma or upgrade CUCM.
Michael
No there is no comma in the display name .
The problem is that i am not able to dial from the CUPC when in softphone mode.
I am getting a message that the called number is out of service in CUPC
Red
We need CallManager trace to analyze the call flow.
Michael
Hi Michael
Plz find the tarce logs for CUCM
the number i have dialed from CUPC is 4555,3162,3167 etc
the CUPC i am usind for dialing is 4096 or 3168 where i have changed the DN
Hi Michael
Hi Michael
Red
I couldn't find any INVITE for the number you mentioned. Have you turned on "SIP Call Processing" debug option?
Michael
Hi Michael
Plz find the new loggs that i have taken
The Device name is "upckiransnext".
This is the CUPC .
The DN is 3168 i am tryiong to dial 4555,3162
Also plz let me know jow to enable debug for SIP call processing in the SERVER
Red
I saw a couple INVITEs in the logs, but none of them matches with the DN you dial:
08/06/2009 12:31:07.254 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 202.54.112.194:[5060]:
INVITE sip:004790892839@202.54.112.194:5060 SIP/2.0
Date: Thu, 06 Aug 2009 07:01:07 GMT
08/06/2009 12:31:52.527 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 10.2.10.196:[5060]:
INVITE sip:228@10.2.10.196:5060 SIP/2.0
Date: Thu, 06 Aug 2009 07:01:52 GMT
08/06/2009 12:32:01.871 CCM|//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 202.54.112.194:[5060]:
INVITE sip:0032478186350@202.54.112.194:5060 SIP/2.0
Date: Thu, 06 Aug 2009 07:02:01 GMT
Who is 202.54.112.194? Who is 10.2.10.196?
Michael
Hi Michael
202.54.112.194 is a SIP trunk for ISP but we are not using this This customer used for dialing to number that ios outside the cluster.
The main issue that we are not able to dial number that is registeicred in the cluster.
You can check for the device name " UPCKIRANSNEXT ".
This is the device name of CUPC that is registerd with cucm.
Red
We're not seeing any INVITE on CUCM. Could you do a packet capture on CUPC and see if it ever sent out the INVITE to CUCM?
Thanks!
Michael
Hi Micheal
We have tested it in the Windows 2007 and vista machine will that be a problem.
Aslo find the attached loggs for CUPC
Red
I think the answer was already provided in 4th post of this thread (Jul 29, 2009, 10:03am PST).
Here's the proof in CUPC log:
INVITE sip:3164@10.3.200.51 SIP/2.0
Via: SIP/2.0/UDP 10.2.10.168:50000;branch=z9hG4bK-d87543-834e3e0be514e442-1--d87543-;rport
Max-Forwards: 70
Contact: <4096>
To: <3164>
Solution options:
1) Upgrade CUCM to 7.1.2
or
2) Remove comma from display name (from Active Directory) - "Nehete, Kiran"
I guess you would rate every post to express your sorry? ;) (joking)
Michael
Hi Micheal
Thanks for your help
Can you plz let me know how remove the comma from the Display name parameter in AD.
Red
Go to Active Directory, right-click on the user and choose "Rename" from the context menu.
Michael
Hi Micheal
I have removed the comma fron AD for one user and then checked but still it is not working.
Red
1) You need to make sure the change was populated from AD to CUCM (CUCM > "System > LDAP > LDAP Directory > Perform Full Sync Now")
2) You need to make sure the change was populated from CUCM to CUPS (CUPS > Serviceability > Control Center - Feature Services > Restart "Cisco UP Sync Agent")
3) CUPC log will tell you if there's a comma in the caller's full name.
Michael
405
