Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CUPS 6.0.6 and CUPC 7.0.x DeskPhone Mode not working
Hi Everyone,
we got a Problem when enabling DeskPhone in the CUPC. Serverhealth shows me "invalid credentials". When i take a look at the trace from CTIManager i get the following Errors:
CTI|Available Servers (2)|<CLID::StandAloneCluster>
CTI|authenticationLDAP::Authenticate():exit AUTH_NOT_INITIALIZED|<CLID::StandAloneCluster>
CTI|Error authentication of user for reading configuration |<CLID::StandAloneCluster>
CTI|authenticationLDAP::connect():Exit on Error|<CLID::StandAloneCluster>
CTI|Failure in LdapDeviceList::Initialize()|<CLID::StandAloneCluster>
CTI|authenticationLDAP::authenticateUserWithPassword():Exit on Error|<CLID::StandAloneCluster>
CTI|authenticationDB::login (Done Authenticating using LDAP)|<CLID::StandAloneCluster>
CTI|authenticationDB::login (LDAP FAILED) (-1)|<CLID::StandAloneCluster>
CTI|AuthenticationImpl::setResults:enter|<CLID::StandAloneCluster>
CTI|AuthenticationImpl::setResults retCode= -1|<CLID::StandAloneCluster>
CTI|AuthenticationImpl::setResults logLevel is 3|<CLID::StandAloneCluster>
CTI|CQBEBuilder::BuildQbeMessage(): objectID=3|<CLID::StandAloneCluster>
CTI|CTIHandler::OutputQbeMessage(): TcpHandle=[2:200:7:14] Qbe Prefix={0xb5e408b8,0x7a}
CTI|kCtiProviderOpenFailure - CTI application failed to open provider CTIconnectionId:14 Login User Id:myusername Reason code.:-1932787616
We are using an Openldap for Directory Synch and Authentication. It worked until we upgraded from 6.1.2 to 6.1.4. Any Idea how to troubleshoot?
The LDAP Synchronization works fine with SSL. My OpenLDAP Administrator told me that there is an corrupt SSL-Handshake in his Log at the Timestamp the CTIManager asks for Authentication.
Kind regards,
Vasco
Red
Re: CUPS 6.0.6 and CUPC 7.0.x DeskPhone Mode not working
Go to CUCM > System > LDAP > LDAP Authentication. Change the port from 389 to 3268. Restart CTIManager on all nodes.
Michael
http://htluo.blogspot.com
Hi Michael,
thanks for your reply. I saw that you recommended the same solution in conjunction with LDAP Active Directory. Will this solution also work on OpenLDAP?
Actually we are not using the default (unencrypted) TCP-Port 389. Instead we're using the TCP-Port 8635 with SSL-Encryption for both Directory Synchronization and Enduser Authentication.
Is there a known Bug-ID?
Kind regards,
Vasco
Hy out There,
ist there any solution for that problem. wie are running CuCM 6.1.4 and CuCM 7.1 and on both the same sh....
cheers Floh
522
