Community Member
CUPS 7.0 with one way audio
I'm trying to use the CUPS softphone through the VPN. It works on my Windows XP latop but I get one way audio when I use my MAC. I have noticed there is no VPN 5.x software for the MAC OS. Could this be my problem?
Has anyone got the CUPS softphone do work on a MAC OS through the VPN.
1 REPLY
Red
Re: CUPS 7.0 with one way audio
Usually (if not always), one-way audio and voice quality issues are caused by the network instead of the end-points or servers (CUCM, CUPS, etc.).
To troubleshoot the problem, you need to do a packet capture on both ends.
If both ends sent out RTP packets but the other end didn't receive it, it's a network issue.
Michael
http://htluo.blogspot.com
147
