CUSPA problems. Please help
Can somebody help me. When I double click on the runprog.exe on the Service pack CD under CUSPA it does not do anything. How do I get this program to run? any help would be great. Thanks
Re: CUSPA problems. Please help
I guess you have to click on the vbs file?
Hi -
The executable is called cuspa.vbs. A window will pop up . If prompted, double-click English to continue the installation. On the Welcome screen, click Next. On the Cisco Unity Server characteristics page, set the following fields:
- Configuration (select your required configuration)
- Number of Ports - enter the number of ports you have on the Unity server. The installation uses this number to distinguish between the versions of SQL or MSDE you are running.
Then follow the onscreen prompts.
Ginger
161
