05-30-2014 10:51 AM - edited 03-19-2019 08:14 AM
Hello Guys,
We have a router/VG working in MGCP (CUCM 8.6.2) with SRST configured.
Everything works fine till it fallback to SRST mode.
All the phones get registered and receives calls normally... but when you try to do an external call, it stucks for 1:15~1:30 minutes, when it finally gets external tone and starts to call.
I did some config check and ran some debugs but didn't find anything that may explain it.
Here some configs:
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
RTPTMAI022 uptime is 8 weeks, 4 days, 10 hours, 32 minutes
System restarted at 07:14:54 GMT Mon Mar 31 2014
System image file is "flash:c3845-adventerprisek9-mz.151-4.M5.bin"
Last reload type: Normal Reload
Cisco 3845 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID xxxx
1 FastEthernet interface
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
4 ISDN Basic Rate interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
redirect ip2ip
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
sip
bind control source-interface FastEthernet0/3/0.5
bind media source-interface FastEthernet0/3/0.5
referto-passing
registrar server expires max 3600 min 3600
asserted-id pai
privacy pstn
no update-callerid
early-offer forced
midcall-signaling passthru
privacy-policy send-always
g729 annexb-all
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.211.3.40 port 2000
max-ephones 150
max-dn 150
system message primary Em Modo Local
dialplan-pattern 1 229477... extension-length 3
dialplan-pattern 2 220449... extension-length 3
transfer-pattern ...
call-forward pattern ...
moh cme_music_on_hold.au
multicast moh 239.1.1.6 port 16386 route 10.211.3.40 1.1.1.1
time-format 24
date-format dd-mm-yy
sip-ua
keepalive target ipv4:62.48.131.34:5060
no remote-party-id
retry invite 2
retry register 10
timers keepalive active 100
sip-server ipv4:62.48.131.34:5060
connection-reuse
host-registrar
g729-annexb override
Thanks in advance
05-30-2014 11:58 AM
How many phones do you have? have you check the CPU/Memory usage when SRST is active?
Have you tried using timeout interdigit??
Regards.
Rolando Valenzuela
05-30-2014 12:34 PM
Thanks for you quick response.
I didn't try timeout interdigit yet.
About the CPU utilization, it is running low, we have at about 80 phones there, but even forcing only one to work in SRST (denying traffic to CUCM via ACL in the switchport) the problem still happening.
I saw the topic you sent me, it says that it is realted to CME, so i'm not sure if i can apply that here.
But in my logs i see the call been sent digit by digit as mentioned by that guy.
How can i test and enable the timeout interdigit?
05-30-2014 01:05 PM
Check this: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_t1ht.html#pgfId-1025536
Also, is this for all the external calls? what about internal calls?
Can you share your dial peer configuration (just one or two)
Regards.
Rolando Valenzuela.
06-02-2014 04:40 AM
Thanks Rolando.
I'm keen to think that there might be some dial-peer problem...
When i try an external calls, this is the dial-peer that matches (10):
dial-peer voice 10 voip
description Outboud calls to PSTN
destination-pattern 0T
progress_ind setup enable 3
session protocol sipv2
session target ipv4:62.48.131.34
voice-class codec 100
voice-class sip dtmf-relay force rtp-nte
voice-class sip early-offer forced
voice-class sip options-keepalive
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 9600
dial-peer voice 11 voip
description Outbound calls to PSTN - Emeregncy Services
preference 1
destination-pattern 11[278]
voice-class h323 1
dtmf-relay rtp-nte
About internal calls... they work fine.
About the timeout interdigits... as it is not a CME (it works in a CUCM located on the HQ, using MGCP) i have no telephony-service configured on it where i could put the "timeout itnerdigit" comand.
Daniel
06-02-2014 08:23 AM
So, the router in questions doesn't is not directly connected with the PSTN?
This is an example of the Dial-peer I have:
dial-peer voice 11 pots
description LONG-DISTANCE CALLS
translation-profile outgoing 11
destination-pattern 91[2-9]..[2-9]......$
port 0/1/0:23
forward-digits 11
I'm sending the traffic port 0/1/0:23, but you are using a SIP trunk to 62.48.131.34, what is that node, another gateway?
Where CUCM sends the calls?
Why the patterns are so general?
Rolando Valenzuela.
06-02-2014 08:35 AM
This IP address is a PSTN gateway within our branch.
Every local (0+...) should go to that GW... in fallback or normal operation.
when it comes to SRST every external call matches on that dialpeer, once they need to pull "0" to start.
Here is a debug msg... from where it starts to where it freezes:
RTPTMAI022#term mon
RTPTMAI022#
RTPTMAI022#
RTPTMAI022#
RTPTMAI022#
RTPTMAI022#
RTPTMAI022#
152975: .Jun 2 14:12:42.504: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=229477320, Called Number=, Voice-Interface=0x71DED96C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
152976: .Jun 2 14:12:42.504: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=22663
152977: .Jun 2 14:12:42.504: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
152978: .Jun 2 14:12:42.788: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=ping, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
152979: .Jun 2 14:12:42.788: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
152980: .Jun 2 14:12:42.788: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
152981: .Jun 2 14:12:42.788: //-1/CBFBCB2EA1BE/DPM/dpAssociateIncomingPeerCore:
152982: .Jun 2 14:12:42.788: //-1/CBFBCB2EA1BE/DPM/dpAssociateIncomingPeerCore:
152983: .Jun 2 14:12:42.788: //-1/CBFBCB2EA1BE/DPM/dpMatchSafModulePlugin:
152984: .Jun 2 14:12:42.913: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0, Peer Info Type=DIALPEER_INFO_SPEECH
152985: .Jun 2 14:12:42.913: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=0
152986: .Jun 2 14:12:42.913: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
152987: .Jun 2 14:12:42.913: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=0, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
152988: .Jun 2 14:12:42.913: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
152989: .Jun 2 14:12:43.113: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=09, Peer Info Type=DIALPEER_INFO_SPEECH
152990: .Jun 2 14:12:43.113: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=09
152991: .Jun 2 14:12:43.113: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
152992: .Jun 2 14:12:43.113: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=09, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
152993: .Jun 2 14:12:43.113: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
152994: .Jun 2 14:12:43.313: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=091, Peer Info Type=DIALPEER_INFO_SPEECH
152995: .Jun 2 14:12:43.313: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=091
RTPTMAI022#
152996: .Jun 2 14:12:43.313: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
152997: .Jun 2 14:12:43.313: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=091, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
152998: .Jun 2 14:12:43.313: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
152999: .Jun 2 14:12:43.513: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0919, Peer Info Type=DIALPEER_INFO_SPEECH
153000: .Jun 2 14:12:43.513: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=0919
153001: .Jun 2 14:12:43.513: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153002: .Jun 2 14:12:43.513: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=0919, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
153003: .Jun 2 14:12:43.513: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
153004: .Jun 2 14:12:43.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=09198, Peer Info Type=DIALPEER_INFO_SPEECH
153005: .Jun 2 14:12:43.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=09198
153006: .Jun 2 14:12:43.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153007: .Jun 2 14:12:43.713: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=09198, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
153008: .Jun 2 14:12:43.713: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
153009: .Jun 2 14:12:43.913: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=091981, Peer Info Type=DIALPEER_INFO_SPEECH
153010: .Jun 2 14:12:43.913: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=091981
153011: .Jun 2 14:12:43.913: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153012: .Jun 2 14:12:43.913: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=091981, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
153013: .Jun 2 14:12:43.913: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
153014: .Jun 2 14:12:44.113: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0919813, Peer Info Type=DIALPEER_INFO_SPEECH
153015: .Jun 2 14:12:44.113: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=0919813
153016: .Jun 2 14:12:44.113: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153017: .Jun 2 14:12:44.113: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=0919813, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
153018: .Jun 2 14:12:44.113: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
153019: .Jun 2 14:12:44.313: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=09198138, Peer Info Type=DIALPEER_INFO_SPEECH
153020: .Jun 2 14:12:44.313: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=09198138
RTPTMAI022#
153021: .Jun 2 14:12:44.313: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153022: .Jun 2 14:12:44.313: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=09198138, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
153023: .Jun 2 14:12:44.313: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
153024: .Jun 2 14:12:44.513: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=091981385, Peer Info Type=DIALPEER_INFO_SPEECH
153025: .Jun 2 14:12:44.513: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=091981385
153026: .Jun 2 14:12:44.513: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153027: .Jun 2 14:12:44.513: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=091981385, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
153028: .Jun 2 14:12:44.513: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
153029: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Calling Number=, Called Number=0919813859, Peer Info Type=DIALPEER_INFO_SPEECH
153030: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=0919813859
153031: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
153032: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=0919813859, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
153033: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=13
153034: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153035: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153036: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153037: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=0919813859, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
153038: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153039: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153040: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153041: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153042: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
153043: .Jun 2 14:12:44.713: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153044: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=0919813859, Called Number=0919813859, Peer Info Type=DIALPEER_INFO_SPEECH
153045: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153046: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153047: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153048: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153049: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x0,
153050: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
153051: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153052: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=0919813859, Called Number=, Voice-Interface=0x0,
153053: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=13
153054: .Jun 2 14:12:44.713: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153055: .Jun 2 14:12:44.717: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153056: .Jun 2 14:12:44.717: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153057: .Jun 2 14:12:44.717: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153058: .Jun 2 14:12:44.717: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153059: .Jun 2 14:12:44.717: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153060: .Jun 2 14:12:44.717: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153061: .Jun 2 14:12:44.717: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153062: .Jun 2 14:12:44.717: //-1/CBD07623A1BA/DPM/dpMatchPeersCore:
153063: .Jun 2 14:12:44.717: //-1/CBD07623A1BA/DPM/dpMatchSafModulePlugin:
dialstring=0919813859, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
153064: .Jun 2 14:12:44.717: //-1/CBD07623A1BA/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153065: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153066: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153067: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153068: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153069: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153070: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153071: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153072: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
RTPTMAI022#
153073: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153074: .Jun 2 14:12:44.721: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
I've created dialpeer 13 equal to 10, but to a specific number, only to test.
After the log above, it freezes for 1:30 (approx) then it continues:
RTPTMAI022#
153214: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153215: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153216: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153217: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153218: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=36
4: Dial-peer Tag=35
153219: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=229477320, Called Number=, Voice-Interface=0x0,
153220: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=35
153221: .Jun 2 14:14:53.434: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153222: .Jun 2 14:14:53.438: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
153223: .Jun 2 14:14:53.438: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
153224: .Jun 2 14:14:53.438: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153225: .Jun 2 14:14:53.438: //-1/4C539A000000/DPM/dpAssociateIncomingPeerCore:
Calling Number=229477320, Called Number=0919813859, Voice-Interface=0x0,
153226: .Jun 2 14:14:53.438: //-1/4C539A000000/DPM/dpAssociateIncomingPeerCore:
153227: .Jun 2 14:14:53.438: //-1/4C539A000000/DPM/dpMatchSafModulePlugin:
153228: .Jun 2 14:14:53.438: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153229: .Jun 2 14:14:53.438: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153230: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153231: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153232: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153233: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersCore:
153234: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersCore:
153235: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersCore:
153236: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchSafModulePlugin:
153237: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153238: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersCore:
153239: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersCore:
153240: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersCore:
153241: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchSafModulePlugin:
153242: .Jun 2 14:14:53.442: //-1/4C539A000000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153243: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153244: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153245: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153246: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153247: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153248: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
153249: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
153250: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153251: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
153252: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
153253: .Jun 2 14:14:53.442: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153254: .Jun 2 14:14:53.446: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153255: .Jun 2 14:14:53.446: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153256: .Jun 2 14:14:53.446: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153257: .Jun 2 14:14:53.446: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153258: .Jun 2 14:14:53.446: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153259: .Jun 2 14:14:53.446: //-1/4C539A000000/DPM/dpMatchPeersCore:
153260: .Jun 2 14:14:53.446: //-1/4C539A000000/DPM/dpMatchPeersCore:
153261: .Jun 2 14:14:53.446: //-1/4C539A000000/DPM/dpMatchPeersCore:
RTPTMAI022#Result=Success(0) after DP_MATCH_DEST
153262: .Jun 2 14:14:53.446: //-1/4C539A000000/DPM/dpMatchSafModulePlugin:
153263: .Jun 2 14:14:53.446: //-1/4C539A000000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
RTPTMAI022#
153264: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=229477320, Peer Info Type=DIALPEER_INFO_SPEECH
153265: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=229477320
153266: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153267: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153268: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=22663
2: Dial-peer Tag=35
3: Dial-peer Tag=36
153269: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153270: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153271: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153272: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153273: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
153274: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153275: .Jun 2 14:14:54.622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153276: .Jun 2 14:14:54.626: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
153277: .Jun 2 14:14:54.626: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
153278: .Jun 2 14:14:54.626: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=13
2: Dial-peer Tag=10
3: Dial-peer Tag=35
4: Dial-peer Tag=36
06-02-2014 09:10 AM
Weird...
The call manager send the calls to this gateway first or it send it to 62.48.131.34 directly?
Have you check the DSP resources?
Do you have the same output when the call manger sends the call?
Can you try with the command "show dialplan number 0919813859" to double check if there is a match.
06-02-2014 10:32 AM
When an user call a local number, it goes directly to that GW... it doesn't reach the CUCM.
Any other call (doesn't starting with '0') goes to the CUCM.
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE
35 voip up up .T 1 syst ipv4:10.1.9.35
36 voip up up .T 2 syst ipv4:10.1.9.36
10 voip up up 0T 0 syst ipv4:62.48.131.34 active
12 voip up up 9[347].. 0 syst ipv4:62.48.131.34 active
13 voip up up 0919813859 0 syst ipv4:62.48.131.34
And yes, there's a pattern that matches...
This last one (13) i've created specially to test it.
What sounds really weird is that the router uses the same dialpeer... in or out of fallback mode... so why only when in srst it adds this delay of almost 2 minutes?
i'm getting crazy, i've changed some fallback configs and did configure a new dialpeer... but it stills the same.
If the telephone goes back to normal mode... it completes the call correctly.
06-02-2014 11:24 AM
What I dont complete understand is this:
How the phone bypass CUCM is not using SRST??
If the phone is registered with CUCM, the pattern information should be handled by the call manager.
If CUCM sends the calls directly to the GW, that means the router (RTPTMAI022) never received traffic, right? so we cannot ensure everything works while you are not in SRST.
Did you check your DSP resources? maybe the router is not capable of handle it.
I'm running out ideas, have you tried with TAC?
