Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Difference between CCM 4.1(3) & 4.3(1)
What is the difference between these two. Preparing for Voice exam and CCM 4.1(3) is the stated version. How much of a disadvantage am I if I only have access to 4.3(1)?
Gold
Re: Difference between CCM 4.1(3) & 4.3(1)
If you are referring to CCIE Voice, then I'd personally recommend using CM 4.1(3). It is always better to use the version of CM which is being tested. There are differences, esp multiple feature enhancements which change the way you would configure the same in CM 4.1.
Try to get yourself a copy of CM 4.1(3). That will always be the best bet
I have been looking for the last 2 monts, however, no luck. If you have any ideas on where to look, please let me know.
112
