Community Member
Disaster Recovery System UCM 7.0 Fail SFTP
Hello, can any help me?
I have this issue when a try to make a new backup:
Error - unable to access sftp server, stdErr: Unable to access SFTP server or SFTP server too slow to respond.Please make sure the login credentials and path are correct.
The datas is correct but, looking the log traces I see this:
Executing Maverick SFTP put command for: User: lab_lsantos HostName: 172.23.3.25 from source :/common/drf/dUmmI_Drf to detination : /dUmmI_Drf
Is it possible create :/xxx in plataform intel, with Windows?
Tnx
Red
Re: Disaster Recovery System UCM 7.0 Fail SFTP
If you failed to access SFTP from CUCM, 99.99999% chance the problem is on SFTP other than CUCM.
To test your SFTP, I'd recommend you use a SFTP client (like this one: http://the.earth.li/~sgtatham/putty/latest/x86/psftp.exe).
Also, have a little bit knowledge on directory/sub-directory would help you troubleshoot the problem as well.
For example, could you tell the difference of the following paths?
1) /
2) \
3) .
4) ./
Michael
http://htluo.blogspot.com
Community Member
Tnx Michael,
but I really dont know if is the diference between the OS client e server, because one is Linux and other one is Windows. In WXP the directory/sub-directory slash is "\" and Linux is "/".
Is it the problem, in your oppinion?
Tnx a lot
Red
For most of the SFTP servers, "/" and "\" are the same. But depending on the server, "/" and "./" could be different.
For example, SFTP servers on Windows usually treat "/" as "SFTP root". But SFTP servers on Linux usually treat "/" as system root. If the login account does not have permission on system root, that could cause problem.
Here are some recommendations:
1) Use FreeFTPd for testing. Because it's freeware and widely used (and proven to work with CUCM).
2) Use "." or "./" as the path in CUCM DRS configuration. "." and "./" means "current directory" or "user's directory".
3) Test SFTP server with SFTP client to verify connectivity and permission. I'd recommend you use a command line client. So you are fully aware what path you're in. Test commands include:
cd
mkdir
put
rmdir
Hope this helps.
Michael
Community Member
ran into similar issue where
ran into similar issue where all components restored good except CAR/CDR, the way i got away from this is i restored all of them and let CDR/CAR failed, then i ran another restore and only restored CAR/CDR and it succeeded
4770
