DMA problem
Hi, everyone
I'm working to upgrade callmanager from 4.1(3) to 5.0(4). but I don't make a DMA-backup files.
Plz, see the attach file.
it is capture display include error message. : Failure, windows-based W1 Migration verification.
I find message that DMA-backup files was made by DMA tool 5.0.4. but it doesn't verification.
what is the W1 ???
thanks.
Hall of Fame Super Red
Re: DMA problem
Hi Donghwa,
Have you checked this log file, it may indicate the exact nature of the problem;
Data validation log
Contains any validation errors that are found during the verification of database and directory data during the backup process
File Location C:\CiscoWebs\DMA\Bin
File Name datavalidation.log
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide09186a00806c51d6.html#wp52984
Hope this helps!
Rob
Re: DMA problem
Hello Rob,
Same error message here.
Addition: File datavalidation.log which is supposed to explain why validation failed is not produced in C:\CiscoWebs\DMA\Bin or any other directory on the server.
Any suggestins?
Alex.
Re: DMA problem
Hi Alex,
I think you should probably open up a case with Cisco Tac. I had a look on the Bug Toolkit and noted 51 Bugs associated with DMA problems on the CCM 5.X train. You might be hitting this one (that does not list any workaround);
CSCsf21021 Bug Details
Headline DMA 5.0(4)ES1.1 backup failed:W1 migration verification & DB in IDS veri
First Found-in Version 5.0(4)
Hope this helps!
Rob
Please remember to rate helpful posts.....
Re: DMA problem
Hi!
I have the same problem.
As I understand, with unverified
tar file I can't continue the process
of upgrading?
Re: DMA problem
I also have the same problem. I have tried the workaround that says in the bug you mention but I'm still having the same problem.
Can anybody please help?
Thanks in advance,
Ruben
Re: DMA problem
There is no workaround in the bug CSCsf21021.
144
