Dropping calls on ring no answer
                   Would like to know how to drop calls when the call is not answered. We are using Cisco Callmanager version 8.6. I don't want the call forwarded to voicemail just want it to drop without annuctiator saying anything.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Joel,
One thing that can be tried is setting the CFNA destination to a Translation pattern which is blocked.
Manish
Hi Joel,
Manish
Re: Dropping calls on ring no answer
Don't configure any behavior for CFNA
java
if this helps, please rate
www.cisco.com/go/pdi
167
