Community Member
DTMF not send with handset
I have a CUCM 6.x and a voice mail system.
When I try to hear a message from my voice mail working fine if I push "messages" softkey of my 7911 ip phone but it doesn't work with handset, It is like the DTMF are not sending or voice mail not understanding this DTMF tones.
It is as if the voice mail did not understand the DTMF.
Any ideas?
Re: DTMF not send with handset
Check out this bug I filed a bit back:
CSCsv04751
Make sure you're not on 8.4.1 or 8.4.1 SR 1
hth,
nick
Community Member
Ok I check it and I have 8.4.1 SR 1
I'll try to downgrade the firmware to workaround and test it.
Thanks Nick!
Community Member
Ok Thanks!!!
I upgrade firmware to 8-4-4 and it is working fine.
130
