Facing a problem while logging Wallet card wizard for unity connection
Hi All,
         Can any one please help on this, i am facing an error while logging to wallet card wizard for unity connection
Error: -
"Error -2147467259 ([informix][informix ODBC Driver][informix]Unspecified System Error = -908. sqlerrm(ciscounity) in procedure cmdConnect_Click of Form frmRemoteConnection"
Nagesh
1 REPLY
Re: Facing a problem while logging Wallet card wizard for unity
There's a section in the help at the to that covers all the things you need to do on the Connection server berfore attempting to connect - is all that in place?  Is the DB PRoxy service running?  Have you installed the Informix ODBC drivers on the client you're on?  There's a link to the ODBC Driver download page off the page of every tool that uses it (including the Wallet Card Wizard) - be sure you install it as the account you're running under (I had a few sites have admins install them under the admin account but not use the "install for everyone" option).
277
