06-04-2014 09:40 PM - edited 03-19-2019 08:16 AM
I run a home lab in which I have two Call Managers (A pub and a sub). Both are registered with the MGCP gateway, and I have no problem making calls. When I fail over to the sub, the phone that I'm using (a cisco 7921) does not failover to the sub. When I check the settings on the 7921, it does not list the sub anywhere. The gateway recognizes that the pub is down, and fails over just fine. I'm sure that I'm missing some obvious configuration somewhere, but I just can't seem to figure out what that is. Any suggestions?
06-05-2014 12:52 AM
Identify the device pool which is assigned to ip phone and make sure that CM group which is assigned to that device pool have both Pub and Sub there.
Suresh.
06-05-2014 11:44 AM
I double checked, and those settings are correct.
06-05-2014 01:19 PM
I would try deleting the CTL:
When the wireless IP phone is connected to a Cisco Unified Communications Manager Release 5.0 or later, you can have multiple security profiles assigned to a phone. When the phone has more than one security profile using different secure Cisco Unified Communications Manager clusters, you must delete the CTL file from the current profile before enabling another profile. See "Understanding Security Profiles" section.
To unlock the CTL file from the Security Configuration screen, follow these steps:
Procedure
Step 1 Scroll to the CTL File menu and press Select.
Step 2 Press **# to unlock options on the CTL File menu.
If you decide not to continue, press **# again to lock options on this menu.
Step 3 Scroll to the CTL option that you want to change and press Erase.
After you make the change, the CTL file will be locked automatically.
06-05-2014 11:38 PM
I just took a look, and there is no CTL file on the phone.
06-06-2014 04:34 PM
I figured it out. It had to do with no entry for DHCP option 150.
06-07-2014 06:23 AM
What you have done exactly as Its seems to be unusual !!! If ip phone registered to a CUCM once, then I think there is no involvement of dhcp option 150 and if Primary cucm is not reachable from IP phone then ip phone should try to register on secondary cucm.
Suresh
