Community Member
Hardware Problems
I try to install CCM6.1(2) in a HP DL380R05, with 4096MB RAM, 2'5GHZ DUAL and the system display what the hardware is uncompatible and i not install the CCM6.1(2).
Can you help me?
Re: Hardware Problems
Supported Cisco Unified Communications Manager Releases by Server
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
Thanks.
My server and my CCM 6.1(2) are compatible.
But I have the following problems:
- I have a HP DL380G5 with 142GB HDD, 4096MB RAM, 2,5GHZ dual processor.
- I introduce the disc of Call Manager 6.1(2) and pass the Hardware Test and I click continue to install the CCM.
- When the system begin to install de CCM, the server told me that the Hardware is not supported for this platform.
Help me please.
A greeting.
I don't see 2.5 GHz as supported
HP Server Solutions
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_solution_overview09186a0080107d79.html
Make sure you exactly match specs from www.cisco.com/go/swonly
java
java
Community Member
Sorry, it is 2,33MHz.
An all is correct with the matrix compatibility.
Community Member
HP DL380G5 Raid array controller shoud be Array P400 Controller with 256MB cache
Community Member
I want to install the following in two separate severs:
- CCM6.1(2) and the server display the errors:
- The hardware is not supported by the system
- IPCC 5.0(2)with OS 2003.1.2:
- BIOS version is P56-09/29/2008. the tested version is P56-12/28/2006, version RAID firmware is 5.22 and firmware support by this system is 2.08. Too, the CPU speed is not the expected 2333MHz, the actual speed is 2500MHz.
What have I do to install those software?
Thanks.
Community Member
What is raid controller name?
Configure disks to raid 1
Community Member
What do you mean with HP DL380G5 Raid array controller shoud be Array P400 Controller with 256MB cache ?
Community Member
You can't install software controller is not P400.
I faced same problem to install CCM 7.0
Community Member
OK.
Thanks for all.
I need to install the P400 controller into the server.
Community Member
I install a firmware of P400 Raid controller to versus 2.08, but i have a problems with the BIOS firmware P56-12/28/2006, when a install into the server, which not start and i have to restore the BIOS firmware again.
I don't know what to do more.
The Media Check of CCM 6.1(2) pass but when i start with the installation appear a message: the hardware is incompatible.
When I try to install Cisco OS 2003.1.2 the same that the Raul's message and me.
Community Member
Check CCM working hardware resources. This may help you
Processor Speed 2333
CPU Type Intel® Xeon (R) CPU 5140 @2.33GHz
Memory 4096 Mbytes
RAID Details
Smart Array P400 in Slot 1
Bus Interface: PCI
Raid 6 (ADG) Status: Disable
RAID 6 (ADG) Enabler Status: Enabled
Controller Status: OK
Chassis Slot:
Hardware Revision: Rev E
Firmware Version: 5.20
Cache Status: OK
Total Cache Size: 256 MB
Logical Drive: 1
Fault Tolerance: RAID 1+0
Status: OK
333
