Community Member
help!ccm4.1 system error message
In the ccm4.1,win2000 system "Computer Management--system tools--event viewer--application "
Every minute error from! Are all "device unregistered",And the phone automatically restart。
Trouble you help me find the problem there?
Thank you!!!!
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date:  3/3/2010
Time:  7:29:28 PM
User:  N/A
Computer: CHNSH-CCM1
Description:
Error: DeviceUnregistered - Device unregistered.
  Device name.: SEP0012D9844D56
  Device IP address.: 10.104.32.161
  Device type. [Optional]: 30007
  Device description [Optional].: 062_FSD_Dong xiao rong_186
  Reason Code [Optional].: 8
  App ID: Cisco CallManager
  Cluster ID: CHNSH-CCM1-Cluster
  Node ID: 10.104.28.137
Explanation: A device that has previously registered with Cisco CallManager has unregistered. This event may be issued as part of normal unregistration event or due to some other reason such as loss of keepalives.
Recommended Action: No action is required if unregistration of this device was expected..
Event Type: Error
Event ID: 3
Date:  3/3/2010
Time:  7:29:28 PM
User:  N/A
Description:
  Device name.: SEP0012D9DA0500
  Device IP address.: 10.104.32.103
  Device description [Optional].: 114_CSC_Zhu hua,Iris_070
1 REPLY
Hall of Fame Super Red
Re: help!ccm4.1 system error message
Hi Yao,
Your going to find that this is a "Network" related issue. Have a look at the examples
below.
https://supportforums.cisco.com/message/1090026#1090026
https://supportforums.cisco.com/message/1094435#1094435
https://supportforums.cisco.com/message/1129635#1129635
CCM_CALLMANAGER-CALLMANAGER-X-DeviceUnregistered
Where "X" = one of these Reason Codes
Value Definition
1 Unknown
2 NoEntryInDatabase
3 DatabaseConfigurationError
4 DeviceNameUnresolveable
5 MaxDevRegExceeded
6 ConnectivityError
7 InitializationError
8 DeviceInitiatedReset
9 CallManagerReset
10 DeviceUnregistered
11 MalformedRegisterMsg
12 SCCPDeviceThrottling
13 KeepAliveTimeout
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/err_msgs/5_x/alarms50.htm
Hope this helps!
Rob
195
