Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Help integrating CM5.1 and LDAP
We keep getting an error message stating that the DN entry is incorrect. We have tried every flavor of cn=xx,o=xx,ou=xx but with no luck. Has anyone else had success with this and if so, could you shine some light on this for me. Any help would be greatly appreciated....
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Help integrating CM5.1 and LDAP
I just did an integration of CM 5.1 to AD,
make sure your search base distinguish name starts from the bottom, fo example assume you AD strucutre:
AD Forest - comnpanyX.com
OU - production
CN - users
the the string should be:
CN=users, OU=production, DC=companyX, DC=com
make sure that the ldap authentication user you specifed has access to the LDAP.
Chris
OU - production
CN - users
Chris
That syntax seemed to the trick, thank you so much for your help!
98
