Help MWI light just stopped working.
I have a client we deployed a UC560 system.  Everythign was working but now the MWI lights stopped working.  I have checked everything I can think of but I can not get them to light up.  Any ideas would be helpful.
I have attached a config.  Below is what I have from the CUE module.
se-10-1-10-1# show ccn application
Description:                            ciscomwiapplication
Application type:                       aa
Script:                                 setmwi.aef
ID number:                              0
Enabled:                                yes
Maximum number of sessions:             6
CallControlGroupID:                     0
strMWI_OFF_DN:                          A801
strMWI_ON_DN:                           A800
Description:                            msgnotification
Script:                                 msgnotify.aef
ID number:                              1
Enabled:                                yes
Maximum number of sessions:             12
DelayBeforeSendDTMF:                    1
logoutUri:                              http://localhost/voicemail/vxmlscripts/mbxLogout.jsp
Description:                            voicemail
Script:                                 voicebrowser.aef
ID number:                              2
Enabled:                                yes
uri:                                    http://localhost/voicemail/vxmlscripts/login.vxml
Todd
Everyone's tags (3)
It could be any number of things, but in your config you have:
ephone-dn  598
number A801...
mwi off
ephone-dn  599
number A800...
mwi on
yet all your numbers appear to be 4 digits; i.e. you'd need "number A801...." and "number A800....".  There could be some translation and such going on.  Otherwise it might be necessary to run some debugs (from CUE, you could do a 'clear trace', 'mwi refresh telephonenumber XXXX', then 'show trace buff long' and see what it's getting back.  CME would have some debugs, too, but at least you'll get some basic info on whether it's getting rejected or not.
I had them with 4 dots and tried with 3 dots.  I put it back but still no luck after doing a MWI refresh.
Are you able to call the MWI On extension from the phone?
Yosh
HTH Regards, Yosh
I usually don't use A800 so I have to admit I don't know how to dial that?  Usually I use just a number so I can dial to turn it on and off?
I will try if you can tell me how?
Todd
I got it to work.  I went back to MWI SIP on the phones and enabled SIP on the Call Manager.
Todd
I have the same problem. Can you explain how you fix the problem? Where did you go back to MWI SIP?
883
