Help on CCME Installation and Configration.
This is our BOM for IPT solution between two locations.
Location1:
a)2851 with Cisco Call Manager Express Feat License For Up To 24 Users.
b)8-Channel Packet Voice/Fax DSP Module.
c)7940 IP Phone With One Call Manager Express Station User Lic.
Location2:
a)2811 Voice Bundle w/ PVDM2-16,FL-CCME-36,SP Serv,64F/256D.
b)Four-port Voice Interface Card - FXO (Universal)- 2 nos
3)8 anolog lines terminated on vic.
Our requirement.
We want inbound from location2. i.e users calling from PSTN to be routed to location1. and Limited outbound from location1.
Pl. suggest what configration goes into both routers.
It will of great help if you send us some inputs. We want most of the features aviable and possible with the above Bill of Matertial. The Link between Location1 and 2 is 512 kbps IPLC.
Thanks and Regards
Bask
  • Unified Communications Applications
1 REPLY
Silver
Re: Help on CCME Installation and Configration.
Hi Bask,
If you have no idea what you are doing and it is your first install. Your best bet is to use the Quick Config tool. Step through the wizard, and you can either let it config the router, or take the generated config and modify it to your hearts content :)
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_data_sheet0900aecd802e9be9.html
Cheers,
Tim.
90
