Help to choose call manager and router SRST reference
I have  a VPN  connection between the headquarter (there is one Cisco2821-sec/k9) and 3  agency (there is one Cisco 2801-hsec/k9 on each agency). the VPN is working fine
I need a complete call manager (soft and hard) with 100 licenses expandable to 300. I will connect it on the switch at the headquarter
Here's what I'll order: is it enough?
MCS-7815-l2-IPC1
CM4.2-K9-7815-I2
Can I use Cisco2821-sec/k9 as CCME at the headquarter, or I must buy another router to replace the linksys
If I can use it as CCME, what should I order ?
I have a router CISCO2801-HSEC/K9 in the agency, and I want to add to this router agency function SRST (30 users), what should I order?
Thanks for your help
Re: Help to choose call manager and router SRST reference
See the architecture in attachement
2 things and an alternative suggestion:
1) I would not deploy a 7815 in a production environment.  They are very limited in scalability and performance and can only be clustered with the same model servers.
2) Why would you choose to purchase an outdated version of CCM in 4.2?  The 4x products, depending on which one is in question, are or are nearing End of Sale and End of Life status.
Alternative:
If you only need 100 licenses, consider purchasing the Linux-based appliance version of CUCM Business Edition.  It supports up to 500 users, is a Linux appliance, and is a co-resident installation of CUCM and Unity Connection.  I would go with 7.1 and specifically install up to 7.1(3b)SU2.
Hailey
Please rate helpful posts!
Thanks for your answer
see below the order option that I choose for 100 users
Part   number
quantity
Description
MCS7828I4-K9-WL
CUCMBE, 7828-I4 appliance, CUWL BE 50 Users
CMBE-WRKSP-BDL
Is it OK ?
Do I need to but another router for voice at the central site (see architecture) or I can use the actual Cisco2821-sec/k9 using for VPN ?
If I can use the Cisco2821-sec/k9 for voice, what is the IOS oder part number option that I should buy ?
What is the order part number that I need to buy to add on each Cisco 2801-hsec/k9 at the agency to have voice and SRST ?
Thanks for your help.
239
