HELP - UM Domino to UM Exchange
I have just been informed that a project I had on the back burner has been moved to the front (effective this week). I need to migrate a Unified Messaging (Domino) solution to Exchange. Here are the details:
CCM 4.1 (PUB and SUB)
Unity UM 4.2(1) (Domino)
UNity VM 4.2(1) (Exchange - separate domain).
IPCC 4.0(4)SR01_Build029
MeetingPlace Express v.2
What are the potential gotchas of this project?
What are the Proper steps for accomplishing this?
In addition to this, I am trying to convince the powers that be that we should co-locate UM and VM (on one box and in our domain). I would then take the other box and configure it as failover to this primary UM/VM solution.
I will also be upgrading IPCC and Call mananger (in the not so distant future).
1 REPLY
Silver
Re: HELP - UM Domino to UM Exchange
You are moving from one Unity server to another without migrating data, you will lose settings and messages if it is a VM solution. If it is a UM solution, you will just lose settings and messages as they would be on your existing Exchange or Domino store.
you need to order:
Part Code Description
UNITY-GRPWARE-CHNG Unity UM, change groupware
UNITY-D2E-USR Convert UM user from Domino to Exchange
UNITY-EXCH-KIT Software kit including Exchange
97
