help with Cisco Unified CME B-ACD
Hi:
I have a cisco callmanager express v 7.1 installed in a 2801 router.
I want to setup a basic CME B-ACD script.  I have 4 DNs from 4000 to 4003, in this setup i need to run the script based on this 4 Dns, i read part of the guide but seems complex for my configuration. i just want when somebody calls, go to the basic assistant and that can calls directly to the stations.  This is my basic configuration.
incoming number 809-323-4322
This is a IP TRUNK service.
CMELAB#show running-config
Building configuration...
Current configuration : 3206 bytes
version 12.4
service password-encryption
hostname CCMELAB
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
no network-clock-participate slot 1
voice-card 0
voice-card 1
dspfarm
ip source-route
ip cef
ip dhcp pool ITS
   network 192.168.0.0 255.255.255.0
   option 150 ip 192.168.0.1
   default-router 192.168.0.1
no ipv6 cef
voice translation-rule 1
rule 1 /^98/ /8/
rule 2 /^918/ /18/
rule 3 /^90/ /0/
voice translation-profile cisco
translate called 1
archive
log config
  hidekeys
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.254
ip http server
tftp-server flash:P00305000600.bin
tftp-server flash:P00305000600.sbn
tftp-server flash:P00308000400.loads
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
dial-peer voice 9 voip
translation-profile outgoing cisco
destination-pattern 9T
session target ipv4:172.19.10.170
incoming called-number 8093234322
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs3 signaling
dial-peer voice 4000 voip
service aa
destination-pattern 4...
session target ipv4:1.1.1.1
incoming called-number 4000
num-exp 8093234322 4000
gatekeeper
shutdown
telephony-service
authentication credential admin cisco
pin 8135 override
max-ephones 5
max-dn 5
ip source-address 192.168.0.1 port 2000
auto assign 1 to 5
load 7960-7940 P00308000400
voicemail 8093234322
max-conferences 8 gain -6
transfer-system full-consult
after-hours block pattern 1 90 7-24
after-hours block pattern 4 9T 7-24
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 4000
ephone-dn  2  dual-line
number 4001
ephone-dn  3  dual-line
number 4002
ephone-dn  4  dual-line
number 4003
ephone-dn  5  dual-line
number 4004
ephone  1
no phone-ui speeddial-fastdial
no phone-ui snr
no multicast-moh
mac-address 0024.2BB0.DAAD
after-hours exempt
type CIPC
button  1:1
pin 8135
ephone  2
no phone-ui snr
no multicast-moh
mac-address 000A.F489.A181
type 7940
button  1:2
pin 8135
ephone  3
no phone-ui snr
no multicast-moh
mac-address 000D.2928.46D6
type 7905
button  1:3
pin 8135
ephone  4
no phone-ui snr
no multicast-moh
ephone  5
no phone-ui snr
no multicast-moh
line con 0
  logging synchronous
login
line aux 0
line vty 0 4
exec-timeout 0 0
  logging synchronous
login
scheduler allocate 20000 1000
end
Hall of Fame Super Gold
Re: help with Cisco Unified CME B-ACD
If it is too complex, you can always hire somebody to configure and test for you.
You will have a professional result and will not be expensive.
Wao, that's truly helpfull and inspired.
thanks..
Neither coming to a board looking hoping for free recipes after browising documentation and finding that is "too much" is an example of inclination toward our line of work.
And the sarcasm doesn't help, so good luck.
504
