09-09-2008 12:33 AM - edited 03-18-2019 09:35 PM
hi,
we have a unity connection 2.1. There is a voice mail box for a directory number. A call incoming to this number is redirected to the voice mail. The caller will be get an announcement, but will not be able to leave a message. After getting the announcement, unity will end the call.
How configure this?
Solved! Go to Solution.
09-09-2008 06:26 AM
there are several options under the subscriber, one of them is After message:
and you have a drop down menu, default is take a message but there is another one called hang up. just change that one
java
if this helps, please rate
09-09-2008 06:26 AM
Please check the "after greeting" call action for this subscriber. Ensure the after greeting call action is set to "take message"
09-09-2008 06:26 AM
java
12-19-2008 02:51 PM
I want to configure the same on a Unity connection 1.2. Is it possible ??
12-19-2008 03:58 PM
sure - you can do this with any version of Unit yor connection back many versions - there's been an "after greeting" action there that includes multiple options (including take message or "hangup") for some years now.
12-20-2008 11:47 AM
Thanks.
In deed, It works fine.
