how to Add users in Unity connection with same Extension
HI Dears ,
can anyone please help me about how to assign voicemail to user with same extensions but different remote site . please discuss breifly
Everyone's tags (2)
You would need to leverage the partition and search space functionality in Unity Connection. These facilities bestow Unity Connection with the ability to achieve a multi-tenant configuration similar to the scenario you describe. Take a look at the following URL:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag235.html
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks my Friend,
     but it did not helped me as much . my scenario is centerlized call processing in which i am using 1 unity connection server voicemail . now we i add some branches and also want to assign voicemail to these user with duplicating extension . unity connection says you can not perform this . can you help me please
Bill has already provided you with the answer to your question and the related documentation, that's exactly what you need.
I'd recommend you to review once again the whole link.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Silver
Rather than trying to use partitions and CSSes on UCXN I suggest you fix your dial plan on CUCM and get away from partitioned dial plan and ensure all DNs in CUCM are unique. You can still allow 4 digit dialing within a dial domain (as long as there is no overlap) by using translation patters to prefix digits. I have done several remediation projects where someone deployed partitioned dial plan and as the deployment grew it was realized that this crated limitations such as the one you point out, or jtapi apps not supporting partitioned dial plans, etc.
HTH,
Chris
thanks Chris ,
     can you please exact configure or snapshots like this kind of things please
thanks
349
