How to connect clients from different Call Managers(CUCM 9)
Hello!
I want to ask you how to make call from Phone 1 to Phone 2?
Phone 1 is registered on Cisco Call Manager 1 and Phone 2 is registered on
Cisco Call Manager 2. Phone 1 and Phone 2 are Cisco IP Communicators. What do I need to do to be able to make calls between this two phones?
Configure an ICT or SIP trunk between the CUCMs, then configure the routing as you wish and use the ICT/SIP trunk to route the calls.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hall of Fame Super Silver
Java is spot on (+5), depending on the version of CUCM you would either do SIP (if both are version 8+) or ICT if one side is older.  This obviously assumes network connectivity between both clusters.
HTH,
Chris
329
