04-26-2010 01:20 AM - edited 03-19-2019 12:51 AM
I have Cisco Meeting Place Express 2.0 installed on server. Meting Place uses Linux (Red Hat) as base operation system.
When I create a premium (scheduled) web/voice/video meeting with 6 participants, everything is good and the meeting is successfully created. But when I try to create a meeting with more then 6 participants I have got the error “Meeting has too many ports to be scheduled”.
My license summary is
Name | Enabled | Installed | Comment |
voiceconf | 40 | 45 | Max that can be enabled on this system: 40 |
webconf | 31 | 31 | Max that can be enabled on this system: 40 |
videoconf | 40 | 51 | Max that can be enabled on this system: 40 |
systemsoftware | 1 | 1 | Valid for version 2.0 |
languages | 1 | 1 |
exchange | 1 | 1 |
stdvoiceconf | 6 | 0 |
stdvideoconf | 6 | 0 |
secondaryservers | 1 | 1 |
As you can see I have enough voiceconf, webconf and videoconf licenses enabled on Cisco MPE.
So why I can not create a meeting with more then default 6 participants? What I must do to solve it?
Thanks in advance
Sincerely yours
Sergey Bondarenko
Solved! Go to Solution.
04-26-2010 10:23 AM
This is controlled by the administrative setting "Maximum ports per meeting for scheduled meetings" under System Configuration > Meeting Configuration.
04-26-2010 10:23 AM
04-27-2010 12:50 AM
Thanks Jonathan.
You are absolutely right. I have corrected ports per meeting values and now everything is ok.
Thank you very march for assistance!
Sincerely yours
Sergey Bondarenko
