Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How to do Call Foward All for a Hunt Pilot without Web Interface
Hello we have CM 4.2 and we have a hunt pilot for the 2 receptionists.
I believe there MUST be a way, either by scripting or a workaround to setup a button to Call Foward All a Hunt Pilot - I will like to do this without depending on the computer to use the Web interface to do it.
Anybody think is possible?
Silver
Re: How to do Call Foward All for a Hunt Pilot without Web Inter
You can change it directly in CCM SQL database.
That would still be PC Dependant. Is there a way that maybe through a "service" on the actual phone or a button that they can easily press.
Silver
Yes, you can create XML service linked to speed dial button (but it only User Interface). so asp/php/??? script generating this service can change Forward All parameter for hunt pilot using SQL Query or AXL API.
regards,
pk
117
