08-25-2008 06:05 AM - edited 03-18-2019 09:31 PM
Is there any particular key set to press when you want to transfer a call to another extention number?
Solved! Go to Solution.
08-25-2008 01:07 PM
Hi Davi,
Good stuff!
You would need to use SCCP for these features to work;
Check out Table 1 from this VG224 doc (show SCCP support for Conference);
http://www.cisco.com/en/US/products/hw/gatecont/ps2250/products_data_sheet09186a00801d87f6.html
Conference Call
Initiates a three-party conference.
During an active call, user presses hookflash for dial tone, dials a third party, and then presses hookflash again to connect all three parties
From this doc;
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a0080483a76.html#wp1178205
Hope this helps!
Rob
08-25-2008 06:32 AM
Hi Davi,
Call Transfer
Connects call to a third party that the phone user dials.
During an active call, user presses hookflash and receives dial tone. User dials number for transfer and either stays online to announce (consultive transfer) or hangs up (blind transfer). When user hangs up, the call is transferred.
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxssccpsplmft.html
Hope this helps!
Rob
08-25-2008 12:06 PM
That Sure Did Help.... but how about conference calls? Can I make Conference Calls using Analog Phones?
08-25-2008 01:07 PM
Hi Davi,
Good stuff!
Conference Call
From this doc;
Hope this helps!
Rob
08-26-2008 10:35 AM
Thanks again Rob.
Solved
