How to use two same extesion at UNITY
Hi Folks,
I have a Unity Cisco Unity 5.0 Build 5.0(1). I need to create two users but they have the sma extesion 9413 but they are in different location (one in Santos the other in the São Paulo).
How can I do to the UNITY distinguish this?
Thank you very much
Elvis Marques www.avvid.net
  • Unified Communications Applications
1 ACCEPTED SOLUTION
Re: How to use two same extesion at UNITY
You can't. Unity needs unique numbers.
You would need to create a new VM profile and add an extra digit in the VM mask and use the same DN in Unity.
One of them needs to turn into a 5 digit DN in Unity.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
This is possible using a combination of voicemail profiles and the multi-tenant MWI setting in CCM. Take a look at the following post.
https://supportforums.cisco.com/message/3014438#3014438
Hope this helps.
Brandon
java
java
247
