if we are 4 pri then how to find out debug for specific calls?
Hall of Fame Super Silver
If you are looking for calls on specific PRI then you can use "debug isdn q931 interface serial " command. If you are looking for call that can arrive on any PRI then "debug isdn q931" will show all calls and for each calls it shows which circuit and channel it arrives on.
HTH,
Chris
but at a time multiple call may happen through PRI and these calls result also will occure in between these debugs then how we can recognisespecific call details?
You look for the dialed number of the number you called or you look for the calling number which is the caller ID of the number you are calling from.
Chris
176
