10-29-2014 03:43 PM - edited 03-19-2019 08:48 AM
In Cisco Unity Connection 10.5 using CUDLI, how can I tell if a mailbox has been initialized and is ready for use by the user? Is there a way to identify if a message has been created by the user?
Solved! Go to Solution.
10-29-2014 04:27 PM
Any mailbox created is ready to be used... not sure quite what you mean there. You can check if the first time enrollment conversation is still active (meaning they have not called into their mailbox yet) if you are using first time enrollment.
you can also check the vw_subscriberTimeLastCall view - the ObjectId of the subscriber account and the time (if any) of the last time they called in on the phone will be in there - the time will be empty if they haven't dialed in yet.
There's no easy way to tell if a user has left a message for someone else (i.e. if that message is deleted you wont find it) without digging through audit logs which is not pretty...
10-29-2014 04:27 PM
