incoming and outgoing calls history
Using a CUCM 5.1, I want to know if it is possible to retrieve an incoming and outgoing calls history of a phone ?
Thanks for help
Alain
No, it's not possible. That info is only stored in the memory from the phone but it's not accesible remotely.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
" CDR search by extension " is it not an option here ?
GP.
Pls rate helpful posts by clicking on stars below the post !!
CDR reports is the best tool you can use for this purpose.
1174
