Incoming CLID Block on CUCM6.1
On CUCM, is there a way to block clid on incoming calls from PSTN to a CUCM controlled extension? That is, how to manipulate call routing based on incoming CLID on CUCM?
Thanks.
Re: Incoming CLID Block on CUCM6.1
not on CUCM only at GW level and ONLY with H323
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Java,
Thanks for the confirmation.
Can I do this on Unity?
Regards.
313
