Installation and integration of expressway for jabber.
Hi ,
We are planning to integrate expressway for external users for jabber  calling without VPN.
Can somebody tell me how the jabber user will login. Will he login to Presence server or Expressway server.?
What will be the role of Expressway E & C in communication and user registration part. and how they should be placed?
if jabber user logs into into presence server do i need to assign an public ip to Presence server.?
I am very much new to Expressway.... Any help would be appriciated.
Thanks... Siddu
  • Unified Communications Applications
Hi Siddu,Please check the
Hi Siddu,
Please check the "Launch Jabber 9.6 externally" section of the following link
http://ciscocollab.wordpress.com/2014/01/
For details of configuration ( Expressway, cucm, presence etc ) for MRA please check the deployment guide below
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-1/Mobile-Remote-Access-via-Expressway-Deployment-Guide-X8-1-1.pdf
Manish
Thanks a lot manish...
Is it supported by TAC..??
Yes, it is supported by TAC
Yes, it is supported by TAC.
Manish
154
