IntraDomain Presence and OCSr2 - TLS issue
I setup the intrafederation according to :
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/8_6/english/integration_notes/Federation/Intradomain_Federation/CUPConfig_chapter.html
I can only talk to Presence from OCSr2 but not the other way.
Also both presence status in ocsr2 and jabber does not work between the ocsr2 and presence.
If i switch the static route 5060 all works, but with 5061 it does not.
Below is the log where "jabbertest1" presence user invites "wegrzyn" OCSr2 user.
I see error like:
11:31:59.928  |ID(2492) sip_sm.c(3738) Route DooS is On for next hop  [10.100.50.81:5061;TLS]. No routes left to process. Terminate the branch  with 404 Not Found.
but i am not sure what this means?
full log:
11:31:59.926 |PID(2492) sip_protocol.c(5994) Received 588 bytes TCP packet from 10.100.95.15:46137
INVITE sip:wegrzyn@equityoffice.com SIP/2.0
From: <sip:jabbertest1@equityoffice.com>;tag=afe8a888-f5f640a-13d8-45026-4ffefbff-382e5d7-4ffefbff
To: <sip:wegrzyn@equityoffice.com>
Call-ID: ae67af10-f5f640a-13d8-45026-4ffefbff-a1bd6a9-4ffefbff
CSeq: 1 INVITE
Via: SIP/2.0/TCP 10.100.95.15:5080;branch=z9hG4bK-4ffefbff-7c085fb5-5cf09ddd
User-Agent: Cisco-Systems-Partitioned 8.0
Max-Forwards: 70
Contact: <sip:10.100.95.15:5080;transport=TCP>
Content-Type: application/sdp
Content-Length: 87
v=0
o=- 0 0 IN IP4 0.0.0.0
s=session
c=IN IP4 0.0.0.0
t=0 0
m=message 5060 sip 0
11:31:59.926  |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.926  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  jabbertest1 is IP or contains non-E164 character, no number expansion  applied.
11:31:59.926 |PID(2492) sip_sm.c(1177) Sent 357 bytes TCP packet to 10.100.95.15:46137
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.100.95.15:5080;received=10.100.95.15;branch=z9hG4bK-4ffefbff-7c085fb5-5cf09ddd
CSeq: 1 INVITE
Content-Length: 0
11:31:59.926 |PID(2492) sip_sm.c(967) TCB_PROXIED_STATE_TIMER : 60 seconds.
11:31:59.926 |ID(2492) sip_sm.c(4846) Non-CUPC request received from IP: 10.100.95.15
11:31:59.926 |PID(2492) mod_sip.c(2950) us_validate_msft_fed_header(): User Agent Header is invalid
11:31:59.926 |ID(2492) sip_sm.c(5027) SIPGW Partitioned Fed UA Header found in this request
11:31:59.926 |ID(2492) sip_sm.c(5060) This is a partitioned federation request, skip User Location DB lookup
11:31:59.926 |ID(2492) sip_sm.c(5250) This is an outbound Partitioned federation request.
11:31:59.926  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.926 |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_routing.c(1426) Routing: dipping for equityoffice.com
11:31:59.926  |Thu Jul 12 11:31:59 2012] PID(2492) imdb_regroute.c(305)  imdb_find_route(): imdb_find_route: search_key is .com.equityoffice,  r_type is 0
11:31:59.926  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(174)  IMDBFindRouteInternal(): IMDBFindRouteInternal: query is select * from  route where contactuser_type = 1;
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5499) IPC message read event
11:31:59.927  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(3886) sip_tcp received  auth state as: 0 for connid: 3 sockfd 34 flags 2 from sip_sm
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 34
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4688) Inside sip_tcp_write_handler
11:31:59.927  |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(680) sip_tcp is now  sending ok pdu 10.100.95.15 connid 3, sock_fd 34 1 msgs
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 8
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(975)  clearRouteIMDBConnection(): clear IMDB route connection
11:31:59.928 |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(263) findMatchingRoutes(): search_key is .com.equityoffice
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(269)  findMatchingRoutes(): destinationpattern is .com.equityoffice, strloc is  .com.equityoffice
11:31:59.928  |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_routing.c(1464) Routing:  Found domain route for equityoffice.com:10.100.50.81:5061;TLS pwf 1:1:5
11:31:59.928 |ID(2492) mod_sip_privacy.c(1197) Honor Privacy at receive. Privacy directive is On.
11:31:59.928 |ID(2492) mod_sip_privacy.c(1257) Upstream 10.100.95.15 is a trusted address.
11:31:59.928 |ID(2492) mod_sip_privacy.c(1265) PrivacyWithPAI is On.
11:31:59.928 |ID(2492) mod_sip_privacy.c(686) Request not authenticated, no PAI header added
11:31:59.928 |ID(2492) mod_sip_privacy.c(1285) PrivacyWithRPID is Off.
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.928  |ID(2492) mod_sip_rtf.c(302) rtf_check_bad_route(): input  CISCO-UA_RTF-10.100.50.81-5061-TLS@corp-cups01, output  52c26fc6-c260b127-521c1ffd-45002f47
11:31:59.928 |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_routing.c(1297) Not to do Less Specific Route Search.
11:31:59.928 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5499) IPC message read event
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(3886) sip_tcp received  auth state as: 0 for connid: 3 sockfd 34 flags 2 from sip_sm
11:31:59.928 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 34
11:31:59.928 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4688) Inside sip_tcp_write_handler
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(680) sip_tcp is now  sending ok pdu 10.100.95.15 connid 3, sock_fd 34 1 msgs
11:31:59.928 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 8
11:31:59.929 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5521) socket read event on: 34
11:31:59.929 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4536) Inside sip_tcp_read_handler
11:31:59.929  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(638) sip_tcp is now  reporting pdu to state machine 10.100.95.15 connid 3, sock_fd 34 0 msgs
11:31:59.929 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 8
11:31:59.929 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4688) Inside sip_tcp_write_handler
11:31:59.929 |ID(2497) sip_protocol.c(5994) Received 442 bytes TCP packet from 10.100.95.15:46137
ACK sip:wegrzyn@equityoffice.com SIP/2.0
To: <sip:wegrzyn@equityoffice.com>;tag=7512ace9-69319ade
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
11:31:59.929  |Thu Jul 12 11:31:59 2012] PID(2497) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.929  |Thu Jul 12 11:31:59 2012] PID(2497) mod_sip_numexpand.c(891) User  jabbertest1 is IP or contains non-E164 character, no number expansion  applied.
11:31:59.929 |PID(2492) sip_sm.c(1177) Sent 413 bytes TCP packet to 10.100.95.15:46137
SIP/2.0 404 Not Found - Route Dynamic Out of Service
CSeq: 1 INVITE
Content-Length: 0
Everyone's tags (3)
Is TLS configured correctly on the CUPS server?   If it does not have the cert, it will not "talk" TLS to OCS Pool server
Did you figure out what the problem was ?
Andri
not, yet , seems like issue with osc not responding on time, still investigating
Did you figure this out?
Did you figure this out?  having the same issue.
761
