Community Member
IP Communicator drops call when VMI light comes on
  Having issue with a user where an active call gets dropped when the user is left a voicemail.  When the VMI light comes on the active call gets dropped.  Additionally the user can't make a call until the voicemail is checked and the VMI light goes off.  I know we experienced this issue in the past but I can't find my notes on the resolution.  Has any one seen this before and knows how to fix it?
Everyone's tags (1)
1 REPLY
Community Member
Re: IP Communicator drops call when VMI light comes on
What version of callmanager are you running?
What version of unity or unity connection ..?
Do a route plan report on your voicemail ports and mwi
See if the dn's overlappp
609
