03-07-2012 09:25 AM - edited 03-19-2019 04:32 AM
I have installed IPC 7.0.5.0 on my Windows 7 box. I have 7942 series phone it works through. I have purhased a CS50 Plantronics wireless headset to work with both the IPC and my 7942. When I go to use the CS50 I can hear the numbers being dialed then it goes to a fast busy. When I dial from a external number I can answer using my IPC and CS50. Any suggestions on how to fix this problem would be greatly appreciated.
Bob
03-07-2012 10:33 AM
OK, what happens if you eliminate the headset and simply use PC speakers to make an outbound call, are you still getting fast busy?
Is this CUCM or CME deployment? What version? Is the IPC configured properly on CUCM to route calls, i.e. proper Calling Search Space if using CUCM?
Chris
03-07-2012 12:43 PM
Hi Chris
Thanks for getting back to me.
The IPC still gets a fast busy when I remove the headset.
I am using CUCM 8.5.1.11900-21
I configured it to the same CSS as my desk phone which works fine. Should there be a different CSS just for IPC?
Bob
03-07-2012 12:56 PM
No need for separate CSS. Couple of things to validate:
Make sure Device Mobility is not messing you up, to check this change the device mobility setting on IPC to OFF
Are you using the same Device Pool for IPC as hard phone, perhaps this is a codec issue, so make sure same DP is used.
Also, you can use Dialed Number Analyzer under serviceability page to check what is going on.
HTH,
Chris
03-08-2012 06:19 AM
I had the Device Mobility set to default so changed to off.
I am using the same DP for IPC and hard phone and I have ran the analyzer but I don’t see any differences between the hard phone and the IPC.
Bob
03-08-2012 06:51 AM
Can you post screen shots of the Phone and IPC configuration as well as the DN configurations?
Are you using MGCP or H323/SIP GW?
Chris
03-08-2012 06:58 AM
03-08-2012 07:00 AM
03-08-2012 07:02 AM
03-08-2012 07:04 AM
03-08-2012 07:07 AM
Yeah, the config is the same on both. So, lets see what happens on the GW, do you know if MGCP or H323 is used and what type of circuit is used for PSTN access? If you can please post the GW config.
Chris
03-08-2012 07:15 AM
03-08-2012 07:17 AM
I need "show run" from the actaul GW.
Chris
03-08-2012 07:18 AM
Oh sorry new to this. Will get!
