Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
IPC Softphone will not dial out gets a fast busy
I have installed IPC 7.0.5.0 on my Windows 7 box. I have 7942 series phone it works through. I have purhased a CS50 Plantronics wireless headset to work with both the IPC and my 7942. When I go to use the CS50 I can hear the numbers being dialed then it goes to a fast busy.  When I dial from a external number I can answer using my IPC and CS50. Any suggestions on how to fix this problem would be greatly appreciated.
Bob
Hall of Fame Super Silver
OK, what happens if you eliminate the headset and simply use PC speakers to make an outbound call, are you still getting fast busy?
Is this CUCM or CME deployment? What version?  Is the IPC configured properly on CUCM to route calls, i.e. proper Calling Search Space if using CUCM?
Chris
Re: IPC Softphone will not dial out gets a fast busy
Hi Chris
Thanks for getting back to me.
The IPC still gets a fast busy when I remove the headset.
I am using CUCM 8.5.1.11900-21
I configured it to the same CSS as my desk phone which works fine. Should there be a different CSS just for IPC?
Bob
No need for separate CSS.  Couple of things to validate:
Make sure Device Mobility is not messing you up, to check this change the device mobility setting on IPC to OFF
Are you using the same Device Pool for IPC as hard phone, perhaps this is a codec issue, so make sure same DP is used.
Also, you can use Dialed Number Analyzer under serviceability page to check what is going on.
HTH,
Chris
I had the Device Mobility set to default so changed to off.
I am using the same DP for IPC and hard phone and I have ran the analyzer but I don’t see any differences between the hard phone and the IPC.
Bob
Can you post screen shots of the Phone and IPC configuration as well as the DN configurations?
Are you using MGCP or H323/SIP GW?
Chris
Phone conf on hard phone
DN on hard phone
IPC Phone conf
IPC DN
Thanks – hope this explains what I am missing!
Bob
Yeah, the config is the same on both. So, lets see what happens on the GW, do you know if MGCP or H323 is used and what type of circuit is used for PSTN access?  If you can please post the GW config.
Chris
H.323
I need "show run" from the actaul GW.
Chris
Oh sorry new to this. Will get!
922
