Community Member
iso replacement
Hey all,
I have a CCO account and an active contact on our CUCM cluster. I need to download an ISO of CUCM 8.0.  All i'm seeing is .sgn in the cisco downloads section.
Do i need to go through my vender to get replacement media?
1 REPLY
iso replacement
No bootable media is provided on CCO, either you use PUT to get it or you do so thru a vendor.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
262
