IVR disconnection issue
Dear Cisco Support,
I have a CUCM6.0 server with IVR 5.0 integration.
I have an issue when calling Cisco IVR..in deed, IVR doesn't disconnect the call once we hungup the call from internal/external.
Can you please give me some clues to fix it
Many Thanks
MF
1 REPLY
VIP Super Bronze
Re: IVR disconnection issue
What IVR product are you using? IP IVR, UCCX, CVP, etc?
If you are using UCCX/IP IVR then you need to add an On Exception (contactInactiveException) step to your script. A script won't watch for caller abandonment unless you tell it to.
Example:
Start
Accept
On Exception (contactInactiveException) GoTo END
...script logic...
Terminate
LABEL: END
End
Note: Do NOT allow the exception to process any other steps besides End without a Clear Exception step. Doing so will cause an exception loop.
153
