Max calls, Busy Trigger, Shared Line & Second Call
Following situation :
1 x Deskphone with shared line 5000 , 1 x WLAN phone also with same shared line 5000.
If I get now a call and using the Deskphone then I can get a second call on my WLAN phone .
I´m searching now  for a solution that the caller get in this case a busy and not a ring on the
second phone with the same shared line.
I checked several cisco documentations but it´s still not clear how I can change the configuration to get
this above solution.
Does anyone know a workable  solution ?
Thanks for help.
2 ACCEPTED SOLUTIONS
Try max number of calls 2 and busy trigger 1.
Please rate helpful answers!
Hall of Fame Super Red
Hi Alex,
Did you set the Busy Trigger to 1 on both devices?
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Tried this but it did not work. For my understanding this setting is per device
( Multiple Call / Call Waitnig Settings on Device SEP......... ).
Hi Alex,
Cheers!
Rob
- Bob Marley
Ok tested it again and now it works .
Many Thanks for help.
423
