MCS7825I4-K9 ethernet redundancy
The  MCS7825I4-K9 has 2 ethernet ports. Manuals are not clear on how to set these up in redundant mode. I have connected the second interface but that doesn't work. I can't find how to configure this.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Evan,
Just to add a note to the info from Graham (+5)
"NIC Teaming for Network Fault Tolerance
The NIC teaming feature allows a  server to be connected to the Ethernet via two NICs and, therefore, two  cables. NIC teaming prevents network downtime by transferring the  workload from the failed port to the working port. NIC teaming cannot be  used for load balancing or increasing the interface speed.
Hewlett-Packard  server platforms with dual Ethernet network interface cards can support  NIC teaming for Network Fault Tolerance with Cisco Unified CM 5.0(1) or  later releases.
IBM server platforms with dual Ethernet network interface  cards can support NIC teaming for Network Fault Tolerance with Cisco  Unified CM 6.1(2) and later releases. "
And the command to do that as per  the CUCM OS CLI Reference Guide is:
"set network failover
This  command enables and disables Network Fault Tolerance on the Media  Convergence Server network interface card.
Command Syntax
failover  {enable | disable}
Parameters
enable enables Network Fault Tolerance.
disable  disables Network Fault Tolerance.
Requirements
Command privilege level: 1
Allowed  during upgrade: No "
The referenced guides:
SRND
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/callpros.html#wp1151635
CLI Ref
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_2/cli_ref_712.html#wp40017
Cheers!
Rob
Silver
You need to say what you are trying to install and what version.
Some products support NIC teaming and some do not.
Graham
I'm installing CUCM 8.6.2
Hi Evan,
Command Syntax
Parameters
Requirements
SRND
CLI Ref
Cheers!
Rob
476
